So here's the story. About two weeks ago while pulling the High School Marching Band trailer to Grand Junction, CO, my truck starts acting up. The first thing that I noticed was the throttle sticking at about 35 mph while i'm slowing down to pull in the gas station. I check my tires and take off and all seems fine until I start getting a little stumble, then dead pedal, then the truck just shuts off with a check engine light. It restarts and seems to be running fine but still has the check engine light. I get about 25 miles from home and it just shuts down. Won't restart so I call a tow truck. Before the tow truck gets there, I try it one more time and it fires up. I take this opportunity to unhook the trailer that I'm pulling to make it easier to load. We switch trucks to continue the journey and my Dodge is headed home.
After the weekend, the kids did scored 1st in their class, I do the ignition key deal and get codes 1489,1491 and 1493( maybe it was 1689, 1691 and 1693, I can't remember. ) So I do the research here and decide that Blue Chip is the place I need to call. I explain to Doug @ Blue Chip what is going on and we come to the conclusion that I need to order a VP44. It arrives and I install it this weekend. All goes pretty smooth and I take the time to redo some of the big-line kit that is already on the truck. I fire it up and all seems good. I bring the truck home and my wife and I decide to take it for a test drive since we are taking the kids to the State band competition next weekend. About 15 miles out of town, I'm coming up on some traffic and let off the throttle and it feels like it sticks again. I convince myself that I had the cruise set until a couple of miles down the road and is just shuts off again. I pull off the road, truck dead and try to start it. It fires right up, I rev it up a couple of times and when I put it in gear it dies. I crank it a few times and nothing. Getting ready to call a tow truck and I try it again and it fires up and heads to redline while blowing lots of black smoke. I tap the throttle and shut it down. I try one more time, it fires right up and acts normal. I put it in gear and we drive the 20 miles back home. No check engine light.
The truck is a 2001 that I purchased new. It has 125,000 miles and been a great truck. Shortly after I got the truck, because of posts here, I relocated the stock lift pump, installed a Vulcan Big Line kit and installed a fuel pressure gauge. I watch the fuel pressure gauge like a hawk and it rarely goes below 12 pounds, usually reading in the 14-15 pound area. When it quit the first time, fuel pressure was at about 14 pounds.
When this first happened, I had some thoughts that it my be related to the APPS. I relayed this to Doug when we spoke but both agreed that the VP44 was probably my problem.
Anyone got any Ideas of where to go from here. Will the APPS cause a stuck throttle and random shutdown?
