My Engine Died
What happened:
Was making a run from Victoria,Tx to Ft. Worth, Tx. I had just stopped and gotten fuel and was back up to hiway speed and the engine died like I had turned the key off. I was able to coast off the hiway and into a small truck stop parking lot.
What I have cked and done:
I had just gotten fuel so I thought maybe dirty fuel, changed filter, no difference. When I cked codes, I had four that were not there Monday.
P-0113 intake air charge temp sensor high
P-0193 fuel rail pressure sensor high
P-0237 turbo boost pressure low
P-0341 camshaft position sensor performance/rationality
I have also cracked a injector line to see if any fuel was getting to the injector, it is. I also took the edge box off and hooked it up stock. No difference. The engine will turn over, but will never hit. I now have the truck at a shop back at home to be cked out Monday. A friend came up to pick me and my truck and trailer up. (and deliver my load to Ft. Worth)
It was suggested that possibaly the Edge box might have fried the sensors. Anyone else had a similar problem? I'm throwing it up to the forum, anyone got any ideas?
I posted this message on 8-21 in the Engine and Transmission Forum, since then, the shop I went to did not have the right scan tool to diag. the problem, (they told me they did) but did manage to erase the codes that were there. They are wating for the correct tool but it will be several days before it will get here. It was towed to a dealer who said it had no codes and just let it go at that. The shop seems to think it is the main (high pressure) pump. Is there any way to ck that without a scan tool? Any help will be greatly appreciated since I make my living with this truck and I've been out of service since last Fri. This is a 2003 so it is not the vp 44 pump.
_______________
What happened:
_______________
