I am working on my 1997 2500 5 speed truck. This is what I have:
I put a set of Napa Premium shoes and Centric drums on my truck and I am having problems. I started with a set of Centric shoes that adjusted tighter and tighter, even when braking going forward. I could hear the adjusters whenever I started from a stop. I determined that the shoes were causing a problem by putting the original shoes back on the truck.
I bought a set of Napa shoes and put them on the truck. The truck will coast in neutral and I don't hear the adjusters. The brakes feel good. The trouble s the left brake I'd dragging. We used a non-contact temperature sensor and got 260 degrees on the left and 160 degrees on the right after a short test drive. I swapped the drums left to right and got the same result. I didn't measure he temperature of the drums before I started the brake job. I drove home from my friend's house at the end of e day.
I took it on the highway and felt a vibration that wasn't there before I changed the brakes. The brake smell is noticeable and I can feel the heat off the drum on the left side.
I compared the brakes to my friend's 1996 2500 5 speed that has original brakes. This is true because he bought the truck brand new. My brakes are identical to his so I know that I installed mine correctly. My parking brake cable isn't tight and there is slack in the center bar so the brake shouldn't be causing the problem
I am at a loss to what is causing this problem. Des anyone have an idea of what I am doing wrong or missing?
