I have a mystery pull to the left (driver side) when braking... . #@$%!
So far I: replaced the swaybar links with Maxxlinks.
Replaced tires with stock size BFG AT KO's.
replaced track bar with a bigger Moog Problem Solver track bar. (this made problem worse & alignment off more)
Checked the front brake Calipers: replaced slider pins & greased both sides. Replaced Right caliper as piston was crooked... .
Replaced brake lines because they were rusting & leaking.
Replaced front & rear shocks & steering stabilizer/damper(shock).
Now considering replacing the brake rotors or having them turned in case they are warped... ???? if so I'll also put on new brake pads.
I'm planning on getting the truck Alignment done soon. . Thats why I did all the shocks etc... .
Any Ideas???? This is getting expensive...
Someone said may be Rear brakes/drums (they did make draging noise last fall but was when I was hauling loads of Sand & I thought sand in the drums). .
Or front brake flex hoses? I've also heard possiblly Front bearing but there is no play I can feel.
Anyone had this issue?
