I still can't seem to find out what's causing my truck to smoke off-color; It's not totally white, it looks more of a gray/tan. It doesn't do it all the time, as in every day. It don't smoke when it isn't supposed to,like at idle or anything, just when it normally smokes black. Which it still does. My mileage is still 18-20, oil looks okay,hard to tell if it uses any, I have a couple little leaks anyway.
Drained the fuel filter. Did the cold start-radiator cap off test to see if the headgasket is really blowed, no bubbles. Which it could still be blowed! Still runs great, doesn't look like any boost/EGT change that I can tell. I'm going to get my grandpa's infrared thermometer, and check the exhaust manifold to see if all 6 cyl. are running the same temp. Any ideas? Sorry if this was long.
Thanks much, Steve
Thanks much, Steve
