STOCK 610 max EGT #'s
Exhaust manifold failures
Broken input shaft or flexplate?
To all 05' owners with gauges and STOCK 610's what type of max EGT's numbers are you seeing? How does this compare with the non-600 third gen's numbers? Looking at getting gauges in the near future just want to know what I should be on the lookout for. Thanks all.
I've gotten mine to around 1000*, bone stock post turbo. This was while towing a bobcat rather enthusiastically.
They list for $525. 00, and I got less 15% at the counter. Here is the part #82208790, the should be in today thanks for the reminder.
Dark ram. that was before I put the T. s. T. in. It had 200 miles on it when I put the gauges in. I hooked the tst up without the boost deal that comes with the new setups and it still made about 5 lbs boost over stock. this is on setting 0/0.
J. Davy
What were you seeing for boost stock? After TST without elbow? I would be careful not installing the TST boost elbow. I was going to do that with mine and Mark at TST stated the turbo could see to much boost and go KaBoom... . I think it is from bypassing the MAP sensor, TST is hiding the boost from getting to ECM and the electronic wastegate will not kick in to limit boost. I did how ever adjust the elbow so I can see around 36lbs of boost. When I was running stock I would see 36 lbs. Put on the TST and boost elbow and all I would see was 30lbs. Adjusted the elbow to allow max boost around 36lbs. I have really like the TST. I need more fuel pressure to really see this thing make some power.
Jeff
I did the 1300 today going uphill in 5th around 3000 (I was watching the egt gauge). I think all diesels should come with an egt gauge. I went over 1200 on a stock '01 too. Now that I got the egt gauge in, let the games begin! :D
I did my 1300 exactly the same as swexlin,uphill at 3000 rpm. JPereira,29 lbs stock I seen 32 lugging in lower gear when it was a little cooler out. With tst every setting is progressively more boost. on setting 5hp 3 tq I stick around 40 pounds on 5hp 4 tq I can hit 45 pounds so I don't run it there. My boost elbow should be here today.
Thanks JD, I was more interested in stock truck numbers, I'm working on my 05' and I 'm making a few changes and didn't start with a base number so I'm fishing a little here, my own dumb fault I guess!
-Ken
