Stock Boost on 05
Strange Idle!?!
Automatic High Idle feature... I like it!
How about it - anyone? I've got the same question.
Also does anyone know what the fuel pressure is with the new in-tank pump for the '05?
It's time to order gauges...
Mike
Anyone know about the fuel pressure?
not too much... . 15psi or 30psi will do you for that. [03-04. 5].
hmm... maybe not... thinking, them 05's should have the in tank lift pump... not sure what the pressures will be. . ?
A quick look through my stuff doesn't show any pressure specs for the 05 but previous models operate @ 7-9 psi .
Bob
Mine must be normal then because I usually see 30-32psi boost on hard accelleration. Haven't towed anything heavy enough to really make it jump.
That seems to be the case on 600 and up engines. My 325/600 would boost 32-34 completely stock. It would hit 38-39 with Dr Performance Stage II fuel/boost box. I have an Autometer 60PSI boost gauge.
My 600 spikes to about 32psi or so and then levels off at about 26-27psi. As for fuel pressure, there aren't any psi specs. It's given as a certain amount of flow. Don't remember it off hand. I plan on installing a guage and just making sure it stays at the current level.
