I have allot of questions I guess. Read on if you're bored!
I just installed a boost EGT gauge on my presumeably stock 96 12v 5 speed, and I was wondering what my boost should be at any given RPM. I know I'm probably dreamin on that. Seems like there should be an approximate curve.
Max boost stock?
Before you get too deep in though on that, i'll tell you that I have an SPA Technique combo gauge. crap, I gotta tell ya what I did. I put the boost sensor on the end of a 5 inch tube because it wouldn't fit in the factory manifold hole. The injector pump is in the way. Will that affect the readings?
I'll make fixie when the temps get above zero. My fingers are cold!
The mighty Cummins is supposed to develope peak torque at 1600 rpm, but mine doesn't do ANYTHING until about 1800 rpm, and doesn't really get with the program until about 2100-2200 rpm. The seat of my pants puts peak torque at 2200rpm.
Then power drops off sharply at about 2700 rpm. That's why the steering wheel shaped mark on my forehead. Just about the time I start thinking we're getting somewhere, it's over.
I noticed that on mine, boost peaks at 2500 rpm (about 25 lbs), then drops off as rpm continues up. it doesn't maintain max boost. Should it maintain max boost?
Okay don't harp at me for doing it. Another thread suggested it is not harmful to rev to the governor unloaded. They even suggested it is a proceedure for checking tach calibration. It galled me, but I did it. I eased it up to wot and the rpm stopped at 3125 rpm.
Do I already have a 3gsk in there?
For the first couple of miles on cold days there is a bump in the rpm as I decrease past about 900 rpm, as I let it go back to idle. Is that a stock thing? I've read that 3gsk can do that?
Also while I'm asking, (thanks for your patience) When I first bought it about 4 months ago, I could see very faint black smoke going up a steep hill (wot or nearly so). also, when I wound it up to maybe 2600 rpm on only 2-3 occasions it put out a cloud that would block out the sun. Not every time, and never since those 2 or 3 times.
Do cats get sooty with mild driving/sitting and then "clean out" when you romp on it?
Lately there is NEVER any visible smoke. That's not a bad thing by it's self, but tells me that I'm not fueling like it was before. Right?
I'm in Alaska, maybe it is due to winter diesel?
Thanks for wading through all that!
I'd like to hear your opinions on what you think I'm looking at.
Max boost stock?
