Engine/Transmission (1994 - 1998) stock cam plate
Engine/Transmission (1994 - 1998) Check Engine Light
Engine/Transmission (1994 - 1998) injector ?
hey guys! i was wondering if anyone had detailed instructions on how to slide the cam plate forward, also how much power will i gain from this?
thanks,
Tom
biggy238 said:
I'm gonna say mid to upper 200hp range... . 250-260..... guessing.
Doubtful on an auto transmission truck. I think on a 180 pump results might be in the neighborhood of 40hp.
I find it easier to do so. You already have a pesky injector line to deal with the intake just makes it more a PITA. Bolts are 10MM for the horn and 11MM for the intercooler boots. use a sharp chisel or punch to work it out, if not drill a hole into it a drive a torx head screwdriver down into the hole and back it out. HTH. Jim
