I just finished installing an Autometer fuel pressure gage. The gage is electric, and the sender is installed on the outlet side of the fuel filter/water separator.
Does anyone know what the nominal and minimum fuel pressures are for a VP44? I've done a search, and there is no concensus on the minimum inlet fuel pressure. I'd like to mark the bezel on the gage or make a note of the "do not drive this truck" pressure. I'm not sure what the Cummins spec is.
I'm currently stock in all respects except for one tapped banjo fitting from Geno's. Since I'm out of warranty, I thought the gage would be a good investment to keep the VP44 happy. I'm currently seeing 11 psi at idle and around 5 psi WOT. Will probably do a FASS setup at some point when the $ come through.
Thanks
Thanks
