Competition Stock Truck 1/4 mile question
Competition Muncie Stats
Competition Gene wins
Does anyone know a ball park # of what I can expect my 99 ext cab 4x4 w/ 3. 54's to run in the 1/4 mile? I live in Wisconsin. I want to run it when I run my mustang at the track in a couple of weeks and I want to brace myself for the slow times. What's expected to be a good or poor number for a stock truck? I'm also going to run it with my Comp Box on level 3 and see what the differences are... any ideas on what I should expect with the Comp Box on level 3? I have to keep it on level b/c I want the transmission to hold up until I get the cash for the DTT. Oh yea, it's an automatic.
I tested mine with the Pocket Dyno and got inconsistent times ranging from a best of 17. 5 to 18. 5 at speeds between 75 and 80mph. This will vary a lot depending on how agressively you launch, and a stock transmission isn't going to do well at this. Also, this was at 5000 feet elev. , so you may average better than this. I have an '01 with 3. 54 gears.
I never ran a test on level 3, and now have DDIIs and DTT transmission so wouldn't be a good comparison for you.
Have fun!
I can give you an estimate based on the way my truck performed.
I have a spot where I can do comparison tests, it is approximately1/4 mile- maybe a little more. Stock I was getting about 72 mph, Banks Stinger plus was 80 mph, DTT & 275s got up to 90mph, changed to DD2s and now it is between 95 & 100 mph.
I haven't had a chance to get on a 1/4 mile track but I think these numbers would be close. I dynoed 366 RWHP at MM
Tom
Well I just happened to hit the drag strip yesterday with my "stock" first gen. I have tweaked the pump some and have a modified air box with K&N and straight pipe exhaust. It is a 93' regular cab 4x4 with an auto and 3. 54 gears. I made three passes all at 17. 9 seconds from 66 to 68 mph. Not bad for a "stock" first gen? By the way I launched in 4 wheel drive at about 15 psi. (my poor transmission!)
i can tell you exactly .
BONE STOCK 2000 2500 4x4 , quad cab short bed , 3. 54 gears , LT265 tires , auto trans , an amsoil air filter in the stock airbox ,6856 lbs.
18. 49 @72. 7mph , this was punching it when the lite went green , no building of boost, no manual shifting , just foot to the firewall lift in the traps , . you are stock , lockout OD , you won't be going fast enough and it will probably hurt you if you get that shift , though i honestly don't remeber trying .
I know this doesn't really help with your question, but in Las Vegas I forgot to turn my COMP on one time and I ran 15. 31 @ 87 mph so this was on the BD IV injectors, which dynoed around 345hp with the COMP turned off. This was using 4 wheel drive like I always do.
I used a g tech on my stock 2000 215hp auto short box 4x4,4. 10 gears. It did 18. 11 @72. 0mph. The truck was a slug stock, The day i got it i had an EZ waiting for it. My G tech reads 13. 71-13. 95 now.
2000 4x4 Dually SLT, auto, 3. 54's..... bone stock 18. 1@79, VA (Thanks to Mopar-Muscle :D) and everything else stock: 17. 1@85
I built a little boost at the staging area..... 2000rpm... . no boost gauge. I built too much boost on one run... . broke the rear tires loose all the way through the 60' lights. The owner of the truck was like: :--)
HTH,
Matt
On edit: This was all in 2x4 with stock 35k mile Goodyears... .
dont run 1st gen in 4x4
no need to 4x4 1 st gen its a waste
i ran best time at 240 hp was 17. 1 at 83.
dually 4x4 ext cab in 2x4 if 4x4 mph will drop
i tied all the other lighter 1 st gens at that race
with my 4x4 dually ,
rear air pressure in dually max 30 in all 4
3/4 ton ide say 35 max
a lot of air will make tires spin
if iam at 55 psi in rear duals ill break tires loose in 3 rd
when 40 psi hits
bill
Someone talked about building boost with a 5spd. How can that be?? Sure would like to run my neighbor in his Dakota 318 with the 16. 20 on his windows for the last 3 months. He runs at State Capital dragway every friday night in the bracket racing. I told him I was interested and he and his buddys about fell down laughing. Just wondering what I would run with current bombs?
Oh yeah slid the plate forward a tad and have not dynoed since.
pwk , you don't , thats the big negative to running a stick with a turbo , no way to build boost ...
you could rev the thing against the rev limiter and let the clutch fly ... .
i'm kidding ...
PWK try this
Hold your foot one the brake and fuel at the same time,rev it to 1500 and start to slip your clutch. It will build boost. :D BTW only do this if you're not to concerned about your clutch.
To give you some idea: I have never gotten a timeslip, so I can't say for certain on the time. But, I have a 1/4 mile measured off on a back road, and my truck will do 80-84 MPH at the end.
Jay,
I just ran at Muncie yesterday. My best run was 17. 40 at 75mph - totally stock (except for exhaust). I thought that was pretty good. I was launching in 2wd at about 16 lbs of boost. I may be able to improve on that with less boost off the line (I was breaking the tires loose).
Dave
