Competition Stockton Pulling Video's
Competition DHRA Rulebook is up!
Competition Automatics at Stockton Pull
it worked for me a minute ago maybe it was overloaded
Merreick I sent them to you via e-mail from work on tuesday did you not get them?
BBD
My last e-mail was on Monday @ 8:49am.
Maybe you could re-send them? My E-mail server does not like big e-mails. I found out video's have to be sent one at a time.
No I didn't get them. :confused:
Merrick Cummings Jr
email: -- email address removed --
EDIT: No need to e-mail them, The site is up again. I jumped ship from Chipstien
Cool videos... . who's ladder bars are you all running? They looked kinda the same.....
Mine hops like a rabbit in rut... . gotta get that axle wrap cured before I hook... . :)
Matt
Matt
most of us have home made ladder bars, I have the Fabriteck stage II system wich is great for my very mildly bombed rig, not sure what they will handle. I believe CSutton and Pysch are Fabritecks as well but not the stage II they have the heavier duty ones.
BBD
I have seen a few single-bar setups... . I think this is the way I want to go. All heim joints, beefy tubing and no binding... those are my only requirements. :)
Thanks for the info... . the time has come for me to seriously research a good traction bar... .
Matt
Matt--that's pretty much where I'm headed--should work great--I know Brandon has the Rancho setup--but it's intended for standard cabs only and I think it's with polyuerathane bushings--but it works-----chris
Chris: Keep us updated..... I'd love to have a sweet single bar setup under my truck before TiM... . I want to keep the bouncing/breakage down a little bit. :D
Matt
Chris,
Was that the turbo or should I say turbos spooling down when you pulled your foot off the go pedal to stop the bouncing???
Rick
Yup
Those were the turbos RHarvey. Pretty screamin' eh?:)
Your can tell Chris is a city driver. Bouncebouncebounce, slow down, floor it, bouncebounce, LOCKUMUP!!!!:D
Tape Recordings
Are now available. Mike Crossley made a device which plugs into the TPS to mimic your engine config as you drive. Mort throttle/more turbo screems : ) Stomp on the brake like Chris did and you get the jet engine shutting off sound as well as turbo barking. :rolleyes: :p
