2nd Gen Non-Engine/Transmission Stop Lamp Switch connector
2nd Gen Non-Engine/Transmission Smarty issue: error 14??
2nd Gen Non-Engine/Transmission fuel tank sending unit module
Is there anyone out there who knows where to get a connector replacement for the stop lamp switch for a 1996 Dodge RAM Diesel. Went to the dealer and Dodge can neither provide the connector nor the harness since they have been obsoleted. If some one out there has a wreak with with a toasted harness with one that would do. I have also tried the local junk yard with no luck. The switch is located under the steering wheel kick panel and is removed with a 30 degree rotation. The switch is actuated by the clutch peddle. The connector is side mounted on the switch. I need enough pigtail wire to splice the connector into my existing harness.
