MatthewStark
I was traveling at 30mph and the engine stopped as if the switch had been shut off and the check engine light came on. Using my Genysis Scan tool I retrieved DTC - P1689 (Internal Injection pump Module failure) & P1688 ( ECM and Pump Module communication error). I followed the diagnostic steps in the Dodge Power Train diagnositc manual for P1689 which indictaed a failed ECM, however the live datastream for all other functions from the ECM are still functional. A check of the APPS, Lift Pump pressure, Fuel Inction pump relay, and Crank position sensor test ok.
1. What part has failed, VP44 PUMP MODULE, VP44 Pump itself or the ECM ?
2. Is there a program and connector available for the OTC Genysis scan tool to directly test the VP44 injection pump module and for the ECM ?
