Archived stopped
Archived power steering pump?!?!?
Archived Help. Truck won't idle or idles with a lope
P0370 Fuel Injection Pump Speed/Position
Sensor Sig Lost
Problem caused by internal fuel injection pump failure.
Sounds like the VP is toast!:rolleyes:Do you have any power boxes on the truck like a Comp? Sometimes they can cause erroneous codes. Code 1693 is a companion code and just means you have another code. 1698 is something about codes in the PCM. Maybe check connections?
