STRAIGHT PIPE
Hadley Airhorns
Hadley "Bully" air horn, way cool!
OK guys, I need a wav file of a truck with a straight pipe so I can hear what it sounds like. I am thinking about going straight, but until I hear one. .
Thanks
Rick
RICK
97 2500,CC,5 SPEED, 3. 54 Limited Slip,Psychotty System,K&N, ISSPRO 3" Pyrometer,Silencer Ring Removed
12,000 RBW 5th Wheel Hitch,25' Excel 5th Wheel,Rancho RSX17000 Shocks
I don't want to spend the money for the straight pipe and then have to go back and install a muffler. One other thing that I need to consider is that when I pull into a camp ground at 11 pm, how many people am I going to make mad??
Rick
RICK
Trust me you would like it. I have 4inch downpipe and then 5inch from there back. It sounds great! It isn't that loud at an idle, just when you get on it. I would record mine but I don't have anything to do it with.
99, 4x4, slt, 3500,5spd,
3. 54 gears, black,hoswel bale bed, blue box, Pac-
Brake, 5in. sraightpipe, K&N, silencer ring removed, 5 star aluminum wheels,brushguard, blackouts, eclipse stereo, matrix headlight bulbs, blue neon fog lights, KC Daylighter, Dodge splash guards, Lund Cold Fronts
-- email address removed --
Phil's Page.com
I agree with Phil. You will not want to go back to stock. I ride with the passenger window down so I can soak up that big rig sound. Unless you goose it going into a campground late at night, your engine noise will be louder than your exhaust.
1996 Dodge 2500 SC, SLT, Cummins 12V, 5-spd. , 4X4, JRE 4" exhaust (somebody stole my kitty and my muffler fell off!), TST 280 HP/685 Ft-Lb Uprate Kit, AFC Spring Kit, Horton Fan Clutch, Jacobs/Ram Exhaust Brake, MagHytec Differential Cover, Combo Gauge, K&N Filter, Brite-Box, no turbo silencer ring, full-time fog lights. Prime-Loc and Rancho 9000 shocks coming soon!
The sound is the perfect complement to a removed silencer ring #ad
95 2500 SLT Laramie 3. 54, automatic,Herculiner bed liner, JVC cd out of factory infinity system, southwest grill gaurd (a favorite amongst the deer population), K&N, AFC adjusted, dual straight exhaust out of "gutless" cat, Geno's dual EGT/boost gauge, TST #6 plate slid all the way forward, AFC housing slid all the way forward, silencer ring removed
"Layin' the 'SMOKEDOWN' on their ROOdy Poo CANDY GASSERS!"
I am never one to go with the group, and in this case I have a reason. I ran a straight pipe for 2 days before deciding to install the muffler. The sound was definitely cool #ad
, but at highway speeds under a load, the resonance in the cab will drive you nuts after a few hours. I would prefer a straight pipe in town, but while on the highway with the windows up, gotta muffle it.
Just my $ . 02
'99 Sport 3500 Quad Cab 4X4 /A. T/3. 54 Red w/Downey Cover, Ultra Boards, K& N Filter, DD Stage I Injectors, 4" Exhaust, Pyro/Boost/ Trans Temp.
Towee: '00 American Star 10,000# 5th wheel.
If it ain't a Diesel (Cummins), it ain't a real truck!
Originally posted by RHARVEY:
"how many people am I going to make mad??"
Just the PSD owners!
Bill Lins Wharton, TX 98 2500 QC SLT,12 (the CORRECT # of)valves,NV4500,3. 54 LSD,Manik grille guard,Psychotty Air,Amsoil everywhere, Reading aluminum utility body and bumper,Optima yellow tops- silencer ring, cat,& muffler all stolen.
I like that one Bill! I also feel that if they(PSD)can't run with the big dogs, they had better stay on the porch!!!!!
Rick
RICK
RamKids is right, sounds cool, but has very strong drone around 2100 rpm #ad
I am going to go with a 4" or 5" system in the near future which will be quieter. A straight-piped 3" is MUCH LOUDER than a straight 4" or 5" pipe. With the 3" I have, I love the sharp brapp around 2500rpm when I get on it, and the sound of the turbo spooling down when you let off of it after revving up good #ad
Vaughn
2001 Ram 2500 QC SWB 2wd, Patriot Blue/Driftwood, HO Cummins & 6-speed, 3. 54LSD, Cab & Fog lamps, Camper & Tow Pkg.
BOMBings: K&N RE0880, straight piped, debadged body, AutoMeter Sport Comp Boost & Pyro gauges
Performance: 245rwHP on BD Dyno, 0-60@ 11. 5 sec 17/22 mpg city/hiway
8255 miles (6/21/00)
Instead of the full 4" system, I opted for the poor man's version. I can always move up later. I suspected that my cat was pretty clogged, so I took it off for an inspection. Holding it up to the sun and looking thru the bore yielded nearly a total eclipse, so it wasn't going back on. The idea of driving a crowbar thru it to remove the guts didn't appeal to me either; no emissions inspection to worry about. If anyone questions the exhaust, just answer: "It's a diesel, genius!" I got a 3" ID to 4" ID reducer for $9 and 48" of 4" dia. pipe for $18 (to cover the extra length of the club cab) and put them in as a replacement for the cat and the club cab extendo-pipe. Not a full 4" system, but more of the exhaust runs thru 4" pipe now than before, no more clogged cat, and upgrading won't be as financially depressing because of the low investment. Something to think about. The spool-up is definitely quicker, and the noise is just right.
Phil
Ted Jennetty has a site you could check out. Check for links through TDR site too get there. He's got some sound files that will put a smile on your face.
I had the full 3" straight pipe for years (almost since my truck was new). I then ordered the 4" down pipe and installed a full 4" system with chrome stack. I LOVE it!! The 3" was great, but now it has a TRUE big-rig sound. Not quite as loud in the cab either, surprisingly enough. Mine had the 'resonating' sound at 2000-2100 RPM, but that is gone with the 4" system. It is not too loud, except when in a hard pull, which even then is not too loud to me! I love the "noise" that these engines make without muffler and silencer ring! #ad
Psychotty air sounds good too.....
Now, If I could JUST get my 5th gear back!! #ad
1996 White, Extra-cab, 4X4, 5-speed, 4. 10 Model 80 rear, Laramie Pkg, Rickson Truck Accessories 19. 5" wheels with Michelin 265/70 XZT load range 'G' mud type tires, 4" turbo-back full-straight pipe exhaust with through the bed stack, Mopar brush guard, K&N RE-0880 air filter,"Psychotty Air", removed turbo silencer ring, Banks Boost & Pyro Guages (pillar mounted) 'tweaked' injector pump (cam plate all the way forward, AFC control run all the way in), well over 120k miles, lots of GOOD, BLACK SMOKE!!, Rollin'-S 25-foot, 10 ton flatbed trailer, with Vacuum/Hydraulic brakes, 16. 5" tandem dual Dexter axles.
Vaughn I will have to disagree my truck is louder inside and out with the 5 inch system than the 3 inch system.
Brake, 5in. sraightpipe, K&N, silencer ring removed, 5 star aluminum wheels,brushguard, Westin nerf bars, blackouts, eclipse stereo, matrix headlight bulbs, blue neon fog lights, KC Daylighter, Dodge splash guards, Lund Cold Fronts
Phil's Page.com
Rick,
Here are the JRE sound files, I don't find any straight-piped files anywhere so far... .
Mick2500
4" Sound Files from JRE
2001 2500 ETH/DEE, QuadCab, 4X4, SB, LSD, 3. 54, SLT+, Sport, Intense Blue PC/Agate, Tow Package, Camper Package, 'DC' Bed Cover, Sliding rear window. Ordered 5/01/00... Cancelled 5/30/00... re-ordered 6/02/00... Cancelled again by DC 6/05/00
Gauges (EGT/Boost) and A-Pillar mount Here, 4" Exhaust, Here.
