Which cools better, straight water, or water and antifreeze mix?
I've heard arguments for both. One, straight water cools better because water absorbs more heat per gallon to raise it's temperature one degree than does a mix.
Argument two, since anti-freeze doesn't boil nearly as easy, the mixture cools better, since you can have a higher water temperature raise going through the engine and not boil. Since cooling is a function of temperature differential between the radiator's flowing water and flowing air, the hotter the liquid entering the radiator, the more heat it loses, since hte differential between the water and air is greater.
Well, ok, now that i've made a simple question complex... . Any takers?
Mark
Mark
