Stranded with signal/headlight problem
Saw a Mega Cab Dually
'03 Brake Bleeding ???
I am a new subscriber hoping some one can help.
The truck is a stock '03 3500 series used for hauling RVs and I'm stranded in
Vancouver,BC.
All lights were working on shutdown, but on the next startup 24 hours later
one headlight is working on lowbeam only and the other on highbeam only.
I relplaced a headlite bulb and the problem did not change.
At this point I realized that 3 out of the 4 signals were also not working.
Park and tail lights are OK.
A dealer shop replaced what they called a "front control module" with no success and I'm still stranded. ... help.
PM me your number if you want, I'll see if I can help. I am neither a mechanic or a electrician, but I have a pick-up truck. :D
I have exact same problem as this guy, i have a 2003 2500,
my post is over at the www.dieseltruckresource.com
its at the top of the 3rd gen no drivetrain section.
EXACT same problem, same with headlights, turn signals EVERYTHING.
they are saying its my dash cluster now... Thank you for verifying that the FWD CONTROL MODULE Isnt at fault. .
this makes it point ever more to the dash cluster.
and its the most expensive part i believe...
anyone else have info i might be missin.
