My clutch has felt stange the past few days. If I set in traffic with my clutch depressed for a while I have almost no pedal when I let off, and gear shifts aren't as smooth. I have a SB clutch with only about 50,000 miles on in, and not abused at all. I still have a full reservior of good fluid, so my assumption is there is some internal leak in either the master of slave cylinder. ?. Does that sound correct, and is there any easy way to tell if it would be one from the other?
I'm not getting any slippage, chatter or anything like that. Once engaged no problems.
Also, any hints on where or how much for replacement cylinders?
Thanks
Thanks
