Here's the deal, jump in the truck to start it, put the fobik in the dash and turn it to the crank position to start. Electric starter bumps for a split second then all power disappears (dash, interior, gauges all turn off like the batteries are totally dead). Turn the fobik off and then back on and it fires up normally. It does do this more so if the engine is up to temp and everything under the hood is heat soaked.
Another potentially related issue is an occasional battery light coming on (on the dash). Also, yesterday it went into what I think is a limp mode. Very limited throttle response and virtually no turbo spool. No check engine lights so this has me a little stumped..........
What I've done up to this point is check all battery connections, cables and load test the batteries-all clean and good.
Any ideas or similar experiences?
