OK, here goes: Ive been having problems recently with what "sounds like" a missing cylinder after installing 370's. The problem persists now even after changing back to the 215's. This morning I made a stop at an office building... was gone from the truck for 30minutes. When I re-started, the starter selenoid hung up, and then after getting that unstuck, the motor died and wouldnt re-start. It would crank, but not fire. I pushed the primer about 5 times and the motor started and continues to run fine. My questions are: in your experiences, is this a lift pump problem or an injection pump problem? Do you think the no-start and the "miss" are related? What can I do about the hanging starter, as this is the 5th or 6th time it's happened? Thanks guys.
