HHhuntitall
I've got a strange one here. This may be simple and I just haven't encountered it yet. This truck is leaking in front by the accessory drive, from a plug/bolt just under the small line going to the KSB. Looking down from the driver fender, it's just below and to the left of where the KSB line goes in the top of the pump. It threads in from the front, so the pump will have to be pulled to service. You can't get a regular wrench on it because of the KSB line. It's just a seep, but why is it leaking? It has a copper washer/seal under it. I tried to turn it with a modified 14mm, cut thin for some other project, which barely slid past the line, but it's not loose. Any help from anyone on this would be greatly appreciated. A good schematic would help, too!!
Thanks,
God bless you and yours,
Thanks,
