The saga continues... While my strange noises ended after I replaced the other shock. I had found one shock was binding, the other would not extend fully. Stopping short almost a full 1.5" short of where the new one would extend.
This past Friday my truck developed the dreaded "Death Wobble" . I made the choice to go after the control arms even though they felt tight. Rock auto once again came through with the best prices for my parts. I went with Moog brand for the control arms, $225 for the full set with expedited shipping was way better than the $995 that I saw a set of Senergy control arms listed for. I may regret this choice. Only time will tell.
Upon removal I found the rubber bushings torn free from the steel sleeve. At first I thought this would be normal but the more I looked the more damage I found to the bushings. As it turns out the steel sleeve is not meant to be free to rotate in the rubber. The rubber is not a bearing. In fact once it tears free it rapidly destroys it self. Think about how far the control arm actually moves. It might move 3-5" at the axle but that is only a few degrees at the mounting point. Just enough for the rubber bushing to flex and absorb the rotation and not tear. That is also how they get away with out ever needing lube. In fact Lube would cause the bushing to fail sooner as it would attack the rubber bushing.
That said I can't believe how tight my truck now feels. It's a new truck again. I'm now planning on replacing the track bar as it's the same age as the control arms.
I'm wondering how many of our trucks have failed control arm bushings that "feel good" as my set did.
Biggest pain on the whole job was the upper passenger side control arm. The exhaust needs to be removed , disconnected pushed up out of the way for the bolt to be able to be removed.
Live and learn something new every day, The day you stop learning that's the day you stop living life to the fullest.
Hope this info helps.
