My truck has 77k on it and has the mods listed in my signature. For the last 2 years(20k miles), possibly right after the fire-ring/cam/stud job, but not sure, my truck has used a slight amount of oil between oil changes during daily driving, maybe a 1/4 quart over 3k miles. Last year while pulling a gravity wagon loaded heavy, I used a quart of oil in 25 miles. I just got done from pulling a trailer 400 miles and it used a quart again. It seems like it is from high rpm/boost when my heavy oil use occurs. I can't figure out where it is going though.
My blow-by tube has a steady hazy white stream from it, but doesn't seem excessive, it doesn't have a pulse to it. The blow-by haze reeks like a fresh batch of Rosmella oil is in there, but I'm running 3k mile old CenPeCo oil in it and it shouldn't stink yet, I wouldn't think. I don't seem to be losing any oil out of the breather other than an occasional drip. My exhaust looks nice and clean, not blue. My oil looks nice and somewhat golden yet after 3k miles, it isn't black. I checked the turbo and there isn't any in/out play and minimal side to side play and there isn't any oil present in the compressor housing. I can't find a vacuum leak either.
I put a puke tube catch bottle on today and went out and was running much harder than usual(30 to 40psi) and there isn't any oil in the bottle. I did find some coolant weeping above the oil pressure regulator though.
Could a headgasket cause this? There isn't anything suspicious with the coolant or oil as far as contamination.
Thanks for any help, I'm running out of ideas.
Dan
Dan
