Alan Reagan
I've had a strange ticking vibration for about a month now and couldn't locate the source. I was looking at removing the radio bezel to see if it was a loose wire or something (Thanks Tryingit for the help on that).
Finally, I found it yesterday afternoon. I have the solid center console and I found that when the lower console lid was closed, any lateral pressure would cause it to tick. It was very aggrevating because it would come and go for no apparent reason.
The culprit is the latch on the lower lid. To solve the problem, I used an adhesive backed pad and lined the latch receiver, bottom and sides. Problem solved. I cut a 1/4 inch strip and went down one side, across the bottom and up the other. There didn't appear to be any contact between the latch and receiver sides and there is no interference to the latch from my solution. All I know is that it work and there is no more aggevating ticking coming from the console area.
