Well, I did a search and found a bunch of information. I am hoping the culprit is u-joints (small $) vs a transmission or transfer case issue (big $). Here's my story and I appreciate any help and advise.
I'm not sure exactly when the vibration started, but I noticed it a couple of days ago when towing my 5th from Edmonton, AB to Trinidad, CO. The vibration starts off pretty severe from a dead stop, varies a bit while accelerating to a cruising speed of around 65 mph. While at cruise, the vibration is still there but not as bad. Any time you let off the throttle, the vibration disappears right away.
Once I arrived at my detination and parked the RV, I tried to isolate the vibration. When unloaded the vibration is pretty much the same. The only difference is that now I can hear a distinct "clunk" when you reapply throttle. I tried to replicate the problem with the truck in 4HI. When accelerating everything remained the same, the difference is that the vibration does not go away when throttle input is removed. Return to 2HI and vibration goes away with no throttle.
I have the truck booked into the local dealer to have it looked at on Friday. Any speculation and advise from the members here before I take in it will be greatly appreciated. Knowing what to ask and also what replacement parts to ask for (sealed vs greasable u-joints) will make a huge difference.
