Strapped on my Psychotty Air
Receiver Ball Mount - 4" or 6" drop ???
Need Advice,Combo Guages Vs Single
The behemoth man of the north paid a visit to me today... Thats right Great White paid me a visit on his way south, and he dropped a little package #ad
I now have the Psychotty Air Induction System all installed!! The install is easy. Took a little while to get the hose lined up so that it would fit, but I did about what Alaska Bee did. I drilled exactly where SCOTT did though. I bent the lower bracket a little to let the hole saw in. Make sure you put some kind of covering over the engine. The hole saw really sprays metal chips. I used a lawn trash bag and electrical tape to seal everything off.
Initial impressions: quality product, Great idea for air source, little different sound(tingy sound from air vents, but less whine), PROTECTED AIR FILTER!
I did a test drive and the EGT seemed lower, but the wind was pretty wicked, so it could be a big difference and I wouldn't have seen it due to the wind. I will post again after I pull my typical load up my typical hill.
Cool thing I noticed. Turned air conditioning controls to face and no fan. Running 70 cool breeze on my hand. STEP on the GO pedal: Air lot less! (almost none #ad
Running down the highway(normal throttle), you couldn't detect a difference in the amount of air being put out by cooling system... .
I have a 4. 5" hole saw free for use in Great Falls, Montana. Come and use it if you get lucky and recieve a Psychotty Air unit.
Jack
1997 4x4, 3. 54 rear, 5 spd, red, vinyl floors.
Banks Stinger Plus, BD 4" cat back (minus muffler), K&N SCOTTY Style, Delvac 1, Lund cold front, Shelf-it overhead storage system, CB mounted overhead like the BIG rigs!
Pull Trailswest 2 horse slant, 1972 8' Bell slide in camper (heavy son of a gun), Sylvan 1750 jon with 60/45 Merc. Jet prop, and one great hunting Black Lab
Check out my pics: http://communities. msn.com/BigRedDodge
12 VALVES!!!
horseman, you were lucky Scott stopped by to see you, what with all that 24v bashing on the 12v forum. LOL #ad
Just a thought, maybe you could schedule an event for us NW BOMBers that also flyfish. You could show us your favorite stretch of river... . #ad
Glad to hear your Psychotty Air is working great! Can't wait to add one too! #ad
'98. 5 2500 QC 4x4, (BLACK) SLT Sport, ISB, LWB, 3. 54 LSD, A/T, Glasstite Vision II canopy, Line-X bed liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, Mopar tow hooks, Jordan Research Ultima 2020 trailer brake controller, VDO Vision gauges, '00 Sport headlights with PIAA Super White 9007/9004 bulbs, 4-2-7+4 Brite-Box, PIAA Dual Sport 900 auxiliary lights, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, Bosch 275 hp. injectors, VA CPC, DD Boost Module, Banks Stinger wastegate actuator, "Scotty Air System", BLACK '00 valve cover, Banks Stinger 4" dia. stainless steel exhaust system, BD LV V10/Cummins hybrid TC and valve body, BD modified transmission front pump and PressureLoc, plus many other trick modifications
Where exactly does the Psychotty system get the air from? Inside the cab?
98. 5 2500 QC LB 4x4 5spd, white. BFG 285x75x16
Cummins 24v w/ TST PowerMAX w/EGT and Boost gauges on A-Pillar.
VanAaken CPC. K&N In the factory air box. Stock Injectors, Stock Exhaust (complete with rattling baffles in muffler).
SnugTop, JJ Stainless Running boards, Tow Hooks, Bushwacker Street Flares, and a Cup Smoothie.
57,000 miles (3/20/00)
From Canada! #ad
99 2500 QC, LWB, 5spd, 3. 54 limited slip, Intense Blue, 275HP Injectors
Tow Lite trailer
96 KTM 360 EXC
99 Durango 4x4 360cid
LOL #ad
LOL #ad
you're killin me Jetson. Now I'll probably get taxed for the air I'm using #ad
'96 2500 extcab, SLT, 4x4, auto-3:54 LSD, Dr. Performance#2, Psychotty Air, American wheels, 255/85R16, Bushwacker flares, silence ring & CAT gone, (4 inch T to T on oreder) Mag-Hytek tran & rear, Rhino Liner, EGT-Boost-Tran temp on dash, Reese Titan V hitch... Triple axle Haulmark enclosed toy hauler
