Stucco HELP
VW turbo ?
what a ride!
Anybody know how to do STUCCO
I have a cinder block curved half wall and want to stucco it but have never done stucco before I thought I saw someone use plastic cement for the base coat to fill the uneveness of the cinder blocks when wall curves but from there im lost.
You can use Mason's cement (type S) available from Home Depot for your base, and depending on your desired finish, you can use it for your finish coat as well.
This is about as far as Icould describe how to do it.
P. S. Usually a mason will add some sort of grit to the final coat to help add texture to it.
~Matt
