I've been wrestling with tight parts since I started. I need to change ball joints. Latest problem is a stuck rotor. I've been beating a wood block against the back of the rotor and can't get any movement. Tried beating steel rod against rotor between studs hoping to help break it. Been soaking with WD40. Rotor has never been removed and has 103k miles on it. Any help would be appreciated. Thanks!
