Just a "quick" Saturday morning job that has gone sour.
I recently received my new 16 cm housing from PDR and in spite of the snow and cold, I decided to tackle the job. I have successfully removed the turbine from the engine as a result of the bottom bolt which holds the exhaust side of the turbine assembly being "resistant". With open access to the bolt (14mm), I have succeeded in rounding over the bolt head and am now in a big jam. I have been unable to remove it by any reasonable means. (heat, smaller wrench, vice grips etc. ) I am about to put the grinder to the head of the bolt unless someone has any other suggestions.
All help reasonable or not is greatly appreciated!
Tom
Tom
