I bought the lift pump from Geno's. It is a Cummins part, and they did supply the long studs for it. Makes it much easier but I had made my own several years ago. You can make only one, pull the pump near the block, and then use the original, then it will be up to the block, and stable enough to pull the home made one out and install the original, not really a big problem.
George
