OK, I'm not a hot rodder, so I'm wondering what the theory is behind using studs to bolt the cylinder head in place. I assume it is for greater clamping load due to finer thread pitch, or possibly greater strength of the stud versus a cap screw. ? Cummins quit using studs a long time ago on the 5 1/8" bore engines. Did they do that because it is easier for automated machines to install and torque cap screws?(Hey I only work there I don't ask questions, actually I did ask the question and received no good answer. )
With the use of the current torque turn/ torque to yield cap screws , what is the advantage of studs?
A Johnson
A Johnson
