Here is a list of things that broke on my truck. What else should I expect?
Radiator leaked,transmission lines leaked,front axle seals leaked, front axle u-joints bad, front upper and lower ball joints worn, rear transfer case seal leaked, steering wheel surface worn, starter motor, fuel shut off solenoid,driver side speaker, fuel gauge sender, oil pressure sender. All of the above broke under 75k miles and were covered under extended warranty (the smartest decision I've ever made). Now the truck has 100k and I just discovered the hitch is cracked. The Cummins has performed fine and starts instantly. Any comments on what might break next would be appreciated.
1997 Regular cab 4x4,Auto,3. 55,Amsoil in engine and rear,Edelbrock shocks, Meyers Snowplow,towing package,snowplow package,quad headlights,B. F. Goodrich All Terrains,1997 Harley Heritage Springer
