stumble with fuel box on
Electrical Wire Size
Cant order a 6 speed now??
I recently installed a ez and a blue box on which is set on 30% at around 1900 rpms you get almost like a skip any ideas i used two connections like the pe uses the single prick connectors for installing the blue box could that be it????????????? i know the directions say to use scotch locs do i need to swap these out doesnt happen with blue box off thanks for any help
99 24v auto 3500 4x4 reg cab 3. 55 axle,va cpc,275 injectors,k&n,rhino lining, tinted glass, tonnoue cover heavy duty trailer tow set up goose neck hitch draw tite brake setup,cb,cd player,catz back up lights,amsoil frnt to back,jre exhaust4 wire blue box, pressure lock,bd exhaust brake,JRE style transgo shift kit, a pro torqe extreme convertor, and a magtec trans cover and trans guage,JRE fuel line kit,upgraded fuel pump,braided fuel lines from lift to injector pump,reflashed ecm,power edge ez,fuel pressure guage,3 guage pillar,boost&pyro
You say it doesn't do it with the blue box off? Maybe its possible the BlueBox and the EZ are confusing each other? Does the BlueBox have a built in Boost module? I know the EZ does so maybe they are both trying to talk to the ECM at the same time? Just ideas... ... . As long as your connection is tight it should be fine. Does it only do it with the EZ and BB both connected and on???
Need to isolate which box is causing it and then go from there.
well i had map sensor jumpers hooked up i disconnected the one for the bb and now i have a stumble i figured the one for the ez would work and the truck is more resposive now going to try and reconnect it thanks kat
As far as I know you need both boxes connected to the map sensor in someway for both of them to work properly. I do not have any personal experience with the BlueBox which is why I asked if it had a boost module in it.
I am betting thats where your trouble is. Need to "rethink" or rework how you are attaching to the MAP sensor. Might call Brett at Edge and ask him the bestway to piggyback the MAP sensor with another box.
Thats my suggestion.
Mass,
Unhook the ez and try it again. If you still have a miss it is the conection to the injection pump. Use a scoth lock with alittle silicon. You wont have any more problems. The green wire lets the box know how much boost you are making. If you leave it unhooked the box wont wait to see boost before it starts adding fuel. With a ez i would leave it hooked up. Keep you from over fueling the engine.
I second the idea of a call to Brett. We have a NW BOMBer here that is on his second EZ box... a stumble! He called Brett and I believe, is now returning for a refund.
I have never run anything but my BB. The addition of the EZ counts me out for advice.
