Shortly after leaving the house this morning my truck started stumbling and then just quit all together. I waited a few seconds and restarted after about 5 sec. of cranking - seemed to run fine. Made it back home with check engine light on... cycled the ign. 3 times got a code of p1648 or 1649 - I forget. Anyway, I called the dealer and he said either injection pump, wiring harness or ECM I believe. Anyway, my fear was the injection pump. Truck has 90,000 on it and I was just waiting. Hopefully it will be replaced under warranty and ther won't be an issue. I took the truck to Hunter Dodge in Lancaster, CA and had a talk with the shop foreman named Kurt. I pretty much filled him in on what I know and suspect. I don't think it is lift pump related as I have an auxilary pusher and pressure was good last I checked. Besides, I wouldn't think the truck would start and run stron after. Any chance it is just a wiring harness deal? Foreman said that the electronic portion of the vp44 can go bad but the pump would have to be replaced if that were the case. Any other suggestions on an approach with these guys?
Thanks in advance
Thanks in advance
