Steve St.Laurent
Staff Alumni
My truck's been driving me nuts for the last six months. I've been having to leave my box off it's been so bad. It would cut in and out - BAD. It acted just like a bad connection at the pump wire. All my connections were soldered and I tried everything I could think of. I talked with Mark @ TST quite a bit trying to solve the problem. I resoldered all my connections, tried a new powermax harness, moved the ground from up by the intake horn to the black/tan ground wire in the injection pump harness, new MAP sensor (boost was going up/down 4 psi at steady throttle with the box off). The truck would drive perfect with the box off but as soon as the box was turned on it was awful. Finally Mark said that he had run into 1 truck where they changed everything fuel system related over about 2 weeks and another shop told them it might be the alternator and that fixed his truck. Today I disconnected my alternator and wala the truck was fixed! So I changed out the alternator and everythings fine now. No other indication of an alternator problem at all. It was easy to troubleshoot by disconnecting the large connection at the back of the alternator and driving the truck on the batteries alone (disconnect the batteries before you mess with that cable). I finally have my truck back!! Oo. I highly doubted it was going to fix it even as I was disconnecting the cables - boy was I happy that it did.
