I have a Craftsmans 5/24 Trac-Plus Snowblower.
Has been sitting most of the year and I left gas in it. (Ya I know, stupid)
Well after soaking the carn in carb spray for a few hours it cleaned up nicely.
The problem is when it went back together it dosen't run right.
It will run with the chock open, and the throttle wide open. As soon as you try to let it idle it will die.
It will also do the same with chock half closed or closed.
There are two mixture screws I have been playing with; the one on the bottom of the float bowl, and one on the side of the carb.
Which one does what?? Is it running too fat?? To lean??
I wish it was a diesel!!!! Much easier to tune!!
Justin
Justin
