JeepBuilder
I had mentioned posting in another headlight thread about restoring headlights using a cerakote kit. Well I finally got to it and I am super impressed. Now I would have done this to the Dodgemahal, but I ended up putting in all new lights, relays and pretty much a whole new headlight system that solved my poor night vision issues. So I did do a write on on the work so it is out there for reading. So today I repaired the very foggy headlights on our Toyota Tundra and my wifes 4 runner. Plus I called a neighbor that had a yamaha quad that you could not read his instrument cluster any more and told him to come on over and we would try to fix his problem also. So successful that it was, I brought my Honda quad in the shop also since it was having issues too. It was a great day of making things better. And seeing some pretty impressive results with a little work. Now I had never used Cerakote's headlight restoration kit before. I have used their trim coat on the Dodge trim last year and it looks like I did it yesterday. Already fully familiar with cerakotes air cure products, I knew they are quality. I use several products on car restorations. No primer or catalyst is needed and it is tough as nails. I am just a regular guy consumer and have no relationship with cerakote other than using their stuff. With that being said, lets see what happened today...
Here is the bag it all shows up in. With good instruction videos on you tube, it is pretty easy. Best part is it is a lifetime treatment. You won't have to do this again like some other kits require. It is also UV and UVB proof.
Here is the first headlight set. Pretty fogged out. Not as bad as the 4runner but still needing fixing.
First is a wipe with oxidation remover. 4 wipes per light. Then, After sanding with 2000 grit and final sanding with 3000 grit. It is included, you dry everything super well as water will ruin your work. I stripped the masking and dried it with compressed air and remasked for great results.
After. Super clear and reflecting everything around me.
The wifes 4runner. It was pretty bad. I sanded a long time. You can feel the sand paper drag more on areas that still need sanding.
They include the little yellow sanding disc holder. 2 pads of 2K grit and 2 pads of 3K grit.
After a clean and dry with compressed air, followed by remasking and a ceramic coating wipe, it looks fantastic. The directions say one pass with a 50% overlap. I did a second pass and it left just a hint of a streak on the drivers side. You want to follow the directions exactly. Don't do a second wipe.
Amazing!
My neighbors quad before...
After with sanding and ceramic coating.
My quad before...
My quad after...
The quads were not perfect, but you could see everything better. The trucks turned out excellent. I can say this kit from cerakote really works well. I believe I paid about 24 bucks before shipping for each kit. Worth every penny. I hope this helps other TDR members with headlights that need a good clean up. Nothing like seeing well at night.
Amazing!
My quad before...
My quad after...
