Traveling across Kansas along I-70, the EGTs started rising to 1250 where the had normally been around 950.
There was also a noticeable rise in the coolant temperature. Where both the OEM and aux gauges never rose above 190, they now reach near 210.
There is also a loss of power and/or acceleration. The turbo is still producing 25 to 30 inches of boost.
To keep the temperatures in check, requires a downshift and slower speeds.
I suspect that there may be a sticky valve or a faulty injector. Possibly dumping unburned fuel causing higher temps? The exhaust is smoking heaver than it did before and it is leaving soot on the rear quarter panel.
What do you folks think?? Faulty valve?? Faulty injector???
