Had this problem come up where motor suddenly has no power when I press on the throttle and then it will kick in and run fine. Sometimes it may happen for a little while after start up and then its fine all day. Recently however it has been happening more frequently where I may be coasting (no throttle) down a mountain and then when I press on the pedal it may miss again kick in and be fine again as long as I maintain some throttle.
Truck is 2003 250 HP 5 speed with Smarty Jr set on towing. I've checked for codes and have none. Truck runs very strong otherwise.
Could this be the throttle position sensor?
