2nd Gen Non-Engine/Transmission Suddenyl NO water in fuel light
Engine/Transmission (1994 - 1998) 4" Exhaust
Engine/Transmission (1998.5 - 2002) transmission is dialed in...
When I picked my truck up a few weeks ago the WIF light was lit. I drained and drained and came to the conclusion that the sensor was bad or the filter was bad.
The other day I was going to change out the filter. When I unplugged the WIF sensor wire, I noticed one of the wires had been pulled completely out of the unit. Well, that would explain it.
So I hit up my local Dodge parts store and purchase a new sensor with wires. I get back in the truck, and suddenly, NO MORE WIF?
This light has been on for over 1000 miles now and suddenly it stops? My first though was the bulb burned out, but when you place the ignition in the pre-start position, it lights up along with the 'wait to start' and 'transmission temp' lights.
So--what gives? Anyone have a clue on what would make a WIF sensor with one wire missing suddenly stop reporting water?
It saw you go in and get a replacement. :eek:
When you noticed the wire was out, did you try to put it back in, or was it in a position that it was close and may have worked it self back into the socket just a little, or ground itself out on the flilter housing or the engine?
The wire was WAY pulled out of the housing, not going back in even if I tried. I DID try to ground it out the other day in an effort to see if the light went out but that didn't work.
This is very odd. Good thing I have a replacement. :D
