Summer coming AC question. need help !
Trip Odometer
Gov spring kit and delivery valves
TMc
Please tell me how to use the dye test in the dash to check the evaporator and expansion valve. Reason I ask is I have seen these dye test used under the hood but not inside the cab.
Thanks Tim
1996 3500 87K. auto,3. 54,Ext. cab.
K&N air
Truck looks just like the truck on left side of page 6 issue 31.
1981 Mercedes 300D Non-turbo 174K miles
1987 blue phord 2810 tractor 456 hours.
1986 blue totayota 135K 1 owner
Bought new 1979 shevrolay 5. 7 litter diesel got 19000 miles,it died.
Bought new 1985 geeimsee S-15 gypsie Total lemon.
Very little dye is injected into the system after it has been charged with refrigerant. After the system has been run or runs out,the dye leakage is checked using an altraviolet light and glasses. The only easy way to check for leakage at the evaporator,short of dismantling the dash is to check the drain where the condensation runs out. The dye will show up inside that tube. All the other connections and components are easily seen.
Good luck guys.
It might be the evaporator core that is leaking. It is inside cab behind glove compartment.
Y2K 2500 reg. cab 4x4 slt 2cg package cummins auto 3. 54 limited slip LNC forest green pearl coat agate interior
Hey guys, Anybody out there have a problem holding a charge on their AC? I got a "96" that starting acting up last fall. It'll hold a charge for about a day, Put 2 cans of dye through and checked all connections and found nothing, Are there any known weak links in the dodge system that you have run into ??? I really don't feel like getting bent over at the dealer.
Thanks in advance !!
