Suncoast Torque Converters
Improved AMSOIL Dual By-Pass system
3 guage pod search
Can you please tell me what the website address is for Suncoast Converters. Thanks in advance.
98 Dodge Ram, 2500, 12 valve, auto. trans. , 4 WD. Perf. injectors, HX40 turbo, Pro Torque torque converter, valve body, pump work and lots more! Dana 80 rear end- I had to throw the 70 away after snapping off two pinions in 2 months. Even with all these modifications, I still take a back seat to my husband "White Dodge". www.enterpriseengine.com
Loretta. . its www.suncoastconverters.com
Am running one, and have no problems... JB
99 Black/Agate, Quad,Long bed,4x4, SLT,Auto,HX-40 16cm2 & ATS Exhaust manifold treated to Jet-Hot 2000(Gray),DD stage 3 injectors,4 wire Blue Box,"True" 5 inch Jet-Hot Coated exhaust from turbo to Tailpipe(Over the Axle),Borla Shoot-out Muffler,Suncoast converter, BD valve body and pressure-loc,Mag-Hytec trans pan,Amsoil ATF-4,Mobil Super Delvac 1300,fuel line up-grade from lift pump to filter and from filter to injection pump,Auto meter Ultra lite gauges:Boost,EGT,Fuel Pressure,Trans Temp, Valentine 1, EZ-pass
