I installed this turbo the other night and all i can say is this thing is amazing. IIS really has their stuff together on this one. I have noticed the temps run a little higher at cruising but if you even breath on the pedal like you would towing the temps are way lower and more manageable than they were with the hybrid. I need to put my larger sticks in and see how this baby works. With the large sticks and the hybrid , i could tow heavy on level one and manage the temps ok , i can imagine that the Phatty will definately make towing heavy a pleasure. The install was a breeze, the drain tube needs to be dented slightly to clear the wastegate actuator arm . The IIS hx40 style Downpipe bolts right on no special attention needed. The only thing i wish i would hve thought of was to have the compressor housing polished. that will be a project for another day. My turbo is a 62/14 by the way.
Thank You Brett W.
www.industrialinjection.com
Steve Atkins
Thank You Brett W.
Steve Atkins
