Just installed the super plug. That's one heck of a magnet on it. I crawled down on the ground and grabbed the side step (Westin) and when bring my right hand around the plug latched on to my side step. When installing the plug, I felt spastic because I couldn't get the darn plug in the hole without it attaching itself to the oil pan. It was quite frustrating. It probably didn't help matters that it was starting to get dark. After the 7th or 8th attempt I finally got in in the hole (the drain plug
) and started to thread it... anyone else have one of those times when you're trying to do a very simple task and start shaking your head because you can't believe that you're running into a problem.
... or am I the only one with this luck (I call this luck because I was fighting daylight so of course this is why it happened).
