Pulled the fiver to Branson Missouri this past weekend with the SuperChip in "Tow Safe" mode and only one time could I get the EGT's even close to 1300 degrees and it was a very long slow grade. Temps generally stayed below 1200 degrees on most hills and around 900 degrees when cruising on flat ground. That is with a bhaf with stock exhaust minus the muffler.
I was worried about the Temps after reading the archives about the SuperChip. I'm happy with the results.
Could I try pulling in the "Tow Performance" mode if I kept an eye on the EGT's? Are the temps the only thing I need to be concerned with as far as the engine?
Thanks.
BrianK.
Thanks.
BrianK.
