Has anybody tryed this new item? Or am I just behind the power curve. This is for the Cummins, per e-mail from superchip. The price is less than any box on the market.
The Dodge Micro Tuner is very simple to install. Plug the Micro Tuner into the vehicles ALDL diagnostic port, located inside the vehicle. Program your vehicle with "Superchips Signature Tuning" in just a few minutes.
User options on the "3705" are as follows.
3 Power Levels
40 hp & 75 ft/lb torque
50 hp & 90 ft/lb torque
70 hp & 140 ft/lb torque
Adjusts for different tire size or gear change
Tow Safe
Hi Performance NO TOWING
Hi Perf Towing up to 6000 pounds
There's no need for tools, no need to access the ECU. Tuning the vehicle is simple and straight forward. The Dodge Micro Tuner by Superchips Inc. is of a true plug and play design.
PLUS!!!!!!!!!
The 3705 can also be used as a
Vehicle Diagnostic Tool!!!!!!!
The 3705 can be plugged into any late model Dodge, car or truck, to retrieve Diagnostic Trouble Codes (DTC). This feature helps the user to diagnose today's complex vehicle electronic systems and can not only display the trouble codes, it can also clear the codes too. A complete list of Dodge Diagnostic Trouble Codes will be provided in the user manual for each 3705 Micro Tuner.
Item # 3705-A
Here is the link http://www.super-chip.com/chips/index.html?loadfile=item3705-a.html
3 Power Levels
Tow Safe
PLUS!!!!!!!!!
Item # 3705-A
