It may have never been enabled. I have had mine done twice and it still doesnt work. I'm going back in next week to watch the tech run through the enable process. I have however heard that the Superchip tuner may disable the high idle feature, if it had previously been turned on. You may want to do a search, I think that I had seen that here in the past month.
Hope this helps
J-
ps- you may also want to check, I thought that it also did not work on the HO motors, I just noticed that in your sig line. Although I may be wrong the copy of the TSB kinda hinted at that.
