SuperGlide with Brookside 276
which axle ratio - towing rpm?
Water Heater heads up!!!
Does anyone know which is the correct capture plate to fit the brookside. I have it on order and going to be driving 12hrs to pick it up and want to have the correct capture plate with me. I am being told that Leland is the one that fits can anyone confirm? I was also to dexter bought leland out.
Thanks in advance for your input!
Wow!
I have no idea what a capture plate is or a Superglide (thought it was a Harley Davidson) or a Brookside 276.
Is your post coded?
you need to know the manufacturer of the King Pin... go to the superglide website once you have that and they have the kingpins listed with the capture plate model numbers. I hope I understood you correctly and this should help.
