Superior Friction Reduction
Boost Gauge Install...
Sensor install help........
Thought you guys might like to look at this product. I have used it in my 90 Ford Gasser for the last 30,000 miles and pulled the heads off last spring and it was very clean inside, truck has 125,000 miles on it now. I have seen a demonstration they do with a bearing and add weight to it to create more friction. The bearing stops when like 10-20 lbs are applied with ANY type of commercial oil, synthetic too. They add a couple drops of SFR and they load the bearing up to 100 lbs or so and it still keeps turning. It is a oil fortifier and it works great. I think I will start running it in the CTD now that it is broke it. Here is the web site, give them a call if you have any questions they are great to talk with. The stuff really works! I ran it in my four wheeler and drowned it several times after I changed to watery oil out it still runs great.
http://www.sfrcorp.com/
Just FYI
